Автор Тема: Коды ошибок оригинального протокола "Toyota"  (Прочитано 26031 раз)
Оффлайн swamp lord
  • Карма: +79/-0
  • Андрей я
Код ошибки   Расшифровка
P0101   Mass Air Flow Circuit Range/Performance Problem
P0102   Mass Air Flow Circuit Malfunction (Low Input – Cor “04)
P0103   Mass Air Flow Circuit Malfunction (High Input – Cor “04)
P0105   Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction / 31
P0106   Manifold Absolute Pressure Circuit Problem / 31
P0110   Intake Air Temperature (IAT) Circuit Malfunction / 24
P0112   Intake Air Temperature (IAT) Circuit Low Input – Cor ‘04
P0113   Intake Air Temperature (IAT) Circuit High Input – Cor ‘04
P0115   Engine Coolant Temperature Circuit Malfunction / 22
P0116   Engine Coolant Temperature Circuit Range/Performance Problem (after Engine Operates at Least 20 Minutes, Engine Coolant Temp. Sensor Value is 86°F aka 30°C or less)
P0117   Engine Coolant Temperature Circuit Low Input
P0118   Engine Coolant Temperature Circuit High Input
P0120   Throttle/Pedal Position Sensor/Switch "A" Circuit Malfunction / 41
P0121   Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem / 41
P0122   Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input – Cor ‘04
P0123   Throttle/Pedal Position Sensor/Switch "A" Circuit High Input – Cor ‘04
P0125   Insufficient Coolant Temperature for Closed Loop Fuel Control
P0128   Thermostat Malfunction (Coolant Temperature below Thermostat Regulating Temperature)
P0130   O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) / 21
P0133   O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134   Oxygen Sensor Circuit no activity Detected (Bank 1 Sensor 1) – Cor ‘04
P0135   O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) /21
P0136   O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) / 27
P0139   O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0141   O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142   O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0147   O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150   O2 Sensor Circuit Malfunction (Bank 2 Sensor 1) / 28
P0153   O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0155   O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1) or Oxygen Sensor Heater Current is Less than 0.25 amp, or Exceeds 2 amps or Voltage Drop for the Heater Exceeds 5 Volts (Cam.)
P0156   O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0159   O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0161   O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2) / 28
P0162   O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0167   O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170   Fuel Trim Malfunction
P0171   System too Lean (Fuel Trim) (tens cars) / 25
P0172   System too Rich (Fuel Trim) / 26
P0174   System too Lean (A/F Lean Malfunction, Bank2) / 25
P0175   System too Rich (Bank2) 26
P0176   Fuel Composition Sensor Circuit Malfunction
P0180   Fuel Temperature Sensor "A" Circuit Malfunction
P0190   Fuel Rail Pressure Sensor Circuit Malfunction / 49
P0191   Fuel Rail Pressure Sensor 15 Circuit Range/Performance (Vist.) / 49
P0201   Cylinder No. 1 Misfires Continuously
P0202   Cylinder No. 2 Misfires Continuously
P0203   Cylinder No. 3 Misfires Continuously
P0204   Cylinder No. 4 Misfires Continuously
P0205   Cylinder No. 5 Misfires Continuously
P0206   Cylinder No. 6 Misfires Continuously
P0300   Random/Multiple Cylinder Misfire Detected or Misfiring Of Multiple Cylinders During Same 200- 1000 Engine Revolutions
P0301   Cylinder 1 Misfire Detected
P0302   Cylinder 2 Misfire Detected
P0303   Cylinder 3 Misfire Detected
P0304   Cylinder 4 Misfire Detected
P0305   Cylinder 5 Misfire Detected
P0306   Cylinder 6 Misfire Detected
P0307   Cylinder 7 Misfire Detected
P0308   Cylinder 8 Misfire Detected
P0309   Cylinder 9 Misfire Detected
P0310   Cylinder 10 Misfire Detected
P0311   Cylinder 11 Misfire Detected
P0312   Cylinder 12 Misfire Detected
P0325   Knock Sensor 1 Circuit Malfunction / 52 (Bank 1 or Single Sensor on Cor ’04)
P0327   Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor) - Cor ’04)
P0328   Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor) - Cor ’04)
P0330   Knock Sensor 2 Circuit Malfunction (Bank 2) / 55
P0335   Crankshaft Position Sensor "A" Circuit Malfunction / 12 or 13 (?)
P0336   Crankshaft Position Sensor "A" Circuit Range/Performance or Deviation in Crankshaft & Camshaft Position Sensor Signals (Cam.)
P0339   Crankshaft Position Sensor "A" Circuit Intermittet – Cor ‘04
P0340   Camshaft Position Sensor Circuit Malfunction (Mar.,Cam. Cor ‘04) / 12
P0341   Camshaft Position Sensor Circuit Range/Performance (Bank 1 or Single Sensor) – Cor ‘04
P0351   Ignition Coil “A” Primary/Secondary Circuit – Cor ‘04
P0352   Ignition Coil “B” Primary/Secondary Circuit – Cor ‘04
P0353   Ignition Coil “C” Primary/Secondary Circuit – Cor ‘04
P0354   Ignition Coil “D” Primary/Secondary Circuit – Cor ‘04
P0385   Crankshaft Position Sensor "B" Circuit Malfunction
P0400   Exhaust Gas Recirculation Flow Malfunction
P0401   Exhaust Gas Recirculation Flow Insufficient Detected With Engine Warm & Driven at 50 MPH for 3-5 Minutes, EGR Gas Sensor Value does Not Exceed Ambient Air Temperature By 72°F aka 40°C (Cam.) / 71
P0402   Exhaust Gas Recirculation Flow Excessive Detected
P0403   Exhaust Gas Recirculation Circuit Malfunction / 71
P0410   Secondary Air Infection System Malfunction
P0411   Secondary Air Injection System Incorrect Flow Detected.
P0412   Secondary Air Infection System Switching Valve "A" Circuit Malfunction
P0420   Catalyst System Efficiency Below Threshold (Bank 1) - With Engine Warm & Driven at 20-50 MPH for 5 Minutes, Heated Oxygen Sensors Have Same Wave Patterns (Cam.)
P0430   Catalyst System Efficiency Below Threshold (Bank 2)
P0440   Evaporative Emission Control System Malfunction
P0441   Evaporative Emission Control System Incorrect Purge Flow
P0442   Evaporative Emission Control System Leak Detected (Small Leak)
P0443   Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0446   Evaporative Emission Control System Vent Control Malfunction
P0450   Evaporative Emission Control System Pressure Sensor Malfunction
P0451   Evaporative Emission Control System Pressure Sensor Range/Performance
P0452   Evaporative Emission Control System Pressure Sensor Low Input – Cor ‘04
P0453   Evaporative Emission Control System Pressure Sensor High Input – Cor ‘04
P0456   Evaporative Emission Control System Leak Detected (Very Small Leak)
P0500   Vehicle Speed Sensor Malfunction / 42 (Sensor “A” on Cor ’04)
P0505   Idle Control System Malfunction or Idle Speed Varies Greatly from ECM Target Speed
P0510   Closed Throttle Position Switch Malfunction
P0511   Idle Air Control Circuit – Cor ‘04
P0550   Power Steering Pressure Sensor Circuit Malfunction or Closed Throttle Position Switch Does Not Turn On when Vehicle is Driven
P0560   System Voltage – Cor ‘04
P0605   Internal Control Module Read Only Memory (ROM) Error
P0606   ECM/PCM Processor
P0617   Starter Relay Circuit High – Cor ‘04
P0705   Transmission Range Sensor Circuit Malfunction (PRNDL Input) - Cor ‘04
P0710   Transmission Fluid Temperature Sensor Circuit malfunction
P0711   Transmission Fluid Temperature Sensor Circuit Range / Performance
P0715   Input/Turbine Speed Sensor Circuit Malfunction (Mar.)
P0724   Brake Switch “B” Circuit High – Cor ‘04
P0725   Engine Speed Input Circuit Malfunction
P0740   ECT ECU Malfunction
P0741   Totque Converter Clutch Solenoid Performance (Shift Solenoid Valve SL) - Cor ‘04
P0750   Shift Solenoid "A" (SL1) Malfunction or Shift Solenoid A/B Malfunction
P0751   Shift Solenoid “A” perfgormance (Shift Solenoid Valve S1) - Cor ‘04
P0753   Shift Solenoid "A" (SL1) Electrical Malfunction
P0755   Shift Solenoid "B" (SL2) Malfunction or During Normal Driving, Gear Required By ECM Does Not Match Actual Gear (Cam.)
P0756   Shift Solenoid “B” perfgormance (Shift Solenoid Valve S2) - Cor ‘04
P0758   Shift Solenoid "B" (SL2) Electrical Malfunction
P0760   Shift Solenoid "C" Malfunction
P0763   Shift Solenoid "C" Electrical
P0765   Shift Solenoid "D" (S4 or Shift Solenoid Valve No. 4) Malfunction
P0768   Shift Solenoid "D" (S4 or Shift Solenoid Valve No. 4) Electrical
P0770   Shift Solenoid "E" (Lock-Up Solenoid, also called SL solenoid) Malfunction
P0773   Shift Solenoid "E" (Lock-Up Solenoid) Electrical Circuit Malfunction
P0850   Park/Neutral Switch Input Circuit – Cor ‘04
P0973   Shift Solenoid “A” control Citcuit Low (Shift Solenoid Valve S1) - Cor ‘04
P0974   Shift Solenoid “A” control Citcuit High (Shift Solenoid Valve S1) - Cor ‘04
P0976   Shift Solenoid “B” control Citcuit Low (Shift Solenoid Valve S2) - Cor ‘04
P0977   Shift Solenoid “B” control Citcuit High (Shift Solenoid Valve S2) - Cor ‘04
P1100   Atmospheric Press Sensor Malfunction
P1101   Atmospheric Press Sensor Circuit Range / Performance
P1105   Combustion Press Sensor Malfunction
P1120   Accelerator Pedal Position Sensor Circuit Malfunction / 19
P1121   Accelerator Pedal Position Sensor Range/Performance Problem / 19
P1125   Throttle Control Motor Circuit Malfunction / 89
P1126   Magnetic Clutch Circuit Malfunction / 89
P1127   ETCS Actuator Power Source Circuit Malfunction / 89
P1128   Throttle Control Motor Lock Malfunction / 89
P1129   Electric Throttle Control System Malfunction / 89
P1130   A/F Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1)
P1133   A/F Sensor Circuit Response Malfunction (Bank 1 Sensor 1)
P1135   A/F Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P1136   A/F Sensor Circuit Malfunction (Bank 1 Sensor 2)
P1139   A/F Sensor Circuit Slow Response (Bank 1 Sensor 2)
P1141   A/F Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P1150   A/F Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1)
P1153   A/F Sensor Circuit Response Malfunction (Bank 2 Sensor 1)
P1155   A/F Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P1156   A/F Sensor Circuit Malfunction (Bank 2 Sensor 2)
P1159   A/F Sensor Circuit Slow Response (Bank 2 Sensor 2)
P1161   A/F Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P1180   CNG Pressure Sensor Circuit Malfunction
P1185   CNG Temperature Sensor Circuit Malfunction
P1190   Fuel Pressure Regulator Malfunction
P1200   Fuel Pump Relay/ECU Circuit Malfunction
P1205   Electric Air Pump Circuit Malfunction.
P1210   Injector Control Pressure Above Expected Level / 92
P1215   EDU Circuit Malfunction (Ath.) / 97
P1220   Timer Control Circuit Malfunction
P1221   Venturi Control Circuit Malfunction
P1225   Spill Control Circuit Malfunction
P1230   Venturi Position Sensor Malfunction
P1235   High Pressure Fuel Pump Circuit Malfunction or “Fuel Pump Control Out Of Range” / 78
P1240   Fuel Shutoff Valve Circuit for Delivery Pipe Malfunction
P1245   Fuel Shutoff Valve Circuit for Pressure Regulator Malfunction
P1300   Igniter Circuit Malfunction / 14
P1305   Igniter No. 2 Circuit Malfunction / 15
P1310   Igniter No. 3 Circuit Malfunction /15
P1315   Igniter No. 4 Circuit Malfunction
P1320   Igniter No. 5 Circuit Malfunction
P1325   Igniter No. 6 Circuit Malfunction
P1330   Igniter No. 7 Circuit Malfunction
P1335   Crankshaft Position Sensor (CKP) Circuit Malfunction (During engine running) (Vist., Cam.) / 13
P1340   Igniter No. 8 Circuit Malfunction (1998-2000 Land Cruiser & 2000 Tundra)
P1345   VVT (Variable Valve Timing) Sensor/Camshaft Position Sensor Circ. Malfunction (Bank1)
P1346   VVT (Variable Valve Timing) Sensor/Camshaft Position Sensor Circuit Range/Performance Problem (Bank 1) / 18
P1349   VVT (Variable Valve Timing) System Malfunction (Bank 1) 22 / 59
P1350   VVT (Variable Valve Timing) Sensor/Camshaft Position Sensor Circ. Malfunction (Bank2)
P1351   VVT (Variable Valve Timing) Sensor/Camshaft Position Sensor Circuit Range/Performance Problem (Bank 2)
P1354   VVT (Variable Valve Timing) System Malfunction (Bank 2)
P1357   Exhaust VVT Sensor/Camshaft Position Sensor Circuit Malfunction (Bank 1)
P1358   Exhaust VVT Sensor/Camshaft Position Sensor Circuit Malfunction (Bank 2)
P1360   Exhaust VVT Sensor/Camshaft Position Sensor Circuit Malfunction (Bank 1)
P1365   Exhaust VVT Sensor/Camshaft Position Sensor Circuit Malfunction (Bank 2)
P1400   Sub Throttle Position Sensor Circuit Malfunction
P1401   Sub Throttle Position Sensor Circuit Range/Performance Problem
P1405   Turbo Pressure Sensor Circuit Malfunction
P1406   Turbo Pressure Sensor Circuit Range/Performance Problem
P1410   EGR Valve Position Sensor Circuit Malfunction
P1411   EGR Valve Position Sensor Circuit Range/Performance Problem
P1415   Air Pump Circuit Malfunction/ (AIR) System Bank 1 / 58
P1416   Port Air Circuit Malfunction/ (AIR) System Bank 2 / 58
P1420   Intake Constrictor CTRL Circuit Open or Short
P1430   Vacuum Sensor for HC Adsorber and Catalyst (HCAC) System Circuit Malfunction (HV)
P1431   Vacuum Sensor for HC Adsorber and Catalyst (HCAC) System Circuit Range/Performance Problem
P1436   Toyota-HCAC-System By-Pass Value Impromevent-Open Malfunction (Pri)
P1437   Toyota-HCAC-System By-Pass Valve Close Malfunction
P1437   Vacuum Line Malfunction (HV)
P1455   Vapor Reducing Fuel Tank System Malfunction
P1455   Vapor Reducing Fuel Tank System Leak Detected (Small Leak) (HV)
P1500   Starter Signal Circuit Malfunction
P1505   Switch Signal Malfunction
P1510   Boost Pressure Control Malfunction
P1511   Boost Pressure Low Malfunction
P1512   Boost Pressure High Malfunction
P1515   Inter Cooler System Malfunction
P1520   Stop Light Switch Circuit Malfunction (A/T)
P1525   Resolver Circuit Malfunction
P1565   Cruise Control Main Switch Circuit Malfunction
P1566   Input Signal Circuit Abnormal or Cruise Control Main Switch Circuit Fault
P1600   ECM BATT Malfunction
P1605   Knock Control CPU Malfunction
P1610   Combustion Control CPU Malfunction
P1620   ECT1 Signal Circuit Malfunction
P1625   ESA1 Signal Circuit Malfunction
P1626   ESA2 Signal Circuit Malfunction
P1627   ESA3 Signal Circuit Malfunction
P1630   Traction Control System Malfunction
P1633   ECM Malfunction (ETCS Circuit) or Electronic Throttle Control System (ETCS) Circuit ECM Malfunction
P1636   HV ECU Malfunction
P1637   E(G?)STP signal Malfunction (ESTP Signal Malfunction – Pri)
P1645   Body ECU Malfunction
P1650   Fuel Pressure Up VSV Circuit Malfunction
P1651   VSV For ACIS Circuit Malfunction
P1652   IACV Control Circuit Malfunction
P1653   SCV Circuit Malfunction / 58
P1654   Idle Up VSV Circuit Malfunction
P1655   Idle Purge VSV Circuit Malfunction
P1656   OCV (Oil Control Valve) Circuit Malfunction (Bank 1) / 39
P1657   Purge Cut VSV Circuit Malfunction
P1658   Waste Gate Valve Control Circuit Malfunction
P1659   Super Charger Control Circuit Malfunction
P1660   Air Bleed Control Circuit Malfunction
P1661   Exhaust Gas Control Valve Control Circuit Malfunction
P1662   Exhaust Bypass Valve Control Circuit Malfunction
P1663   OCV (Oil Control Valve) Circuit Malfunction (Bank 2)
P1666   Intake Air Control VSV No.2 Circuit Malfunction
P1667   TCV Circuit Malfunction
P1668   VSV for AICV Circuit Malfunction
P1690   OCV For VVTL Circuit Malfunction (Bank 1)
P1692   OCV For VVTL Open Malfunction (Bank 1)
P1693   OCV For VVTL Close Malfunction (Bank 1)
P1695   OCV For VVTL Circuit Malfunction (Bank 2)
P1697   OCV For VVTL Open Malfunction (Bank 2)
P1698   OCV For VVTL Close Malfunction (Bank 2)
P1700   Speed Sensor No.2 Malfunction
P1705   NC2 (Direct Clutch Speed Sensor) Revolution Sensor Circuit malfunction or Direct Clutch Speed Sensor Output is 300 RPM or less with Vehicle at 20 MPH or more & with Park/Neutral Position Switch Off
P1710   Steering Sensor Circuit Malfunction
P1715   Rear Wheel Sensor Circuit Malfunction
P1720   DC Clutch Forced Release Circuit Malfunction
P1725   NT Revolution Sensor or Input Turbine Speed Sensor Circuit Malfunction
P1730   NC Revolution Sensor Circuit Malfunction or Counter Gear Speed Sensor Circuit Fault
P1735   Right Front Speed Sensor Circuit Malfunction
P1740   Left Front Speed Sensor Circuit Malfunction
P1745   Transmission Fluid Temperature Sensor No.2 Circuit Malfunction
P1753   Shift Solenoid No.4 Circuit Malfunction
P1755   Linear Solenoid for Lock Up Ctrl Circ. Malfunction
P1760   Linear Solenoid for Line Pressure Control Circuit Malfunction or Shift Solenoid Valve SLT Fault or Linear Solenoid for Lock-Up Control Circuit Malfunction
P1765   Linear Solenoid 24 for Accumulator Pressure Control Circuit Malfunction (Shift Solenoid Valve “SLN” malfunction) or with Engine Warm, Current Flow to Shift Solenoid Valve “SLN” is 0.2 Amp or less for One Second with Engine at 500 RPM or more, or with Park/Neutral Position Switch Off
P1770   Deferential Lock Solenoid No.1 Circuit Malfunction
P1775   Deferential Lock Solenoid No.2 Circuit Malfunction
P1780   Park/Neutral Position (PNP) Switch malfunction (A/T only)
P1782   Transfer L4 SW Circuit Malfunction
P1783   Transfer N SW Circuit Malfunction
P1785   Auto Clutch System Malfunction
P1790   ST Solenoid (Shift solenoid valve ST) Circuit Malfunction
P1793   Shift Solenoid ST Circuit Malfunction
P1800   Automatic Transmission Operation Circuit Malfunction
P1805   Communication (between EFI ECU and Transmission ECU) Circuit Malfunction
P1810   Communication for Torque Control Circuit Malfunction
P1820   NIN Sensor Circuit Malfunction
P1825   NOUT Sensor Circuit Malfunction
P1845   PTO Sensor Circuit Malfunction
P1885   SLS Circuit Malfunction
P1888   SLS Circuit Malfunction
P1890   SLC Circuit Malfunction
P1891   SLC Circuit Malfunction
P1895   DSU Circuit Malfunction
P2195   Oxygen Sensor Signal Stuck Lean (Bank 1 Sensor 1) – Cor ‘04
P2196   Oxygen Sensor Signal Stuck Rich (Bank 1 Sensor 1) – Cor ‘04
P2716   Pressure Control Solenoid “D” Electrical (Shift Solenoid Valve SLT) - Cor ‘04
P2769   Torque Converter Clutch Solenoid Circuit Low (Shift Solenoid Valve SL) – Cor ‘04
P2770   Torque Converter Clutch Solenoid Circuit High (Shift Solenoid Valve SL) - Cor ‘04
P3000   HV Battery Malfunction
P3001   26 Battery ECU malfunction
P3002   HV ECU communication malfunction
P3004   Power Cable Malfunction
P3005   High voltage fuse snapped [sic] 27
P3006   Battery SOC are uneven 28
P3009   Leak detected 29 (Electric leak from high–voltage
P3010   Battery total resistance malfunction
P3011   to P3029 Battery block malfunction 30
P3030   Battery voltage detective line snapped [sic]
P3060   Battery temperature sensor circuit malfunction
P3076   Abnormal air flow by battery cooling fan
P3077   Battery cooling fan motor circuit malfunction
P3100   HV ECU Malfunction
P3101   Engine System Malfunction
P3105   Battery ECU Communication Circuit Malfunction
P3106   ECM Communication Circuit Malfunction
P3107   Airbag ECU Communication Circuit Malfunction
P3108   A/C Amplifier Communication Circuit Malfunction
P3109   32 Brake ECU Communication Circuit Malfunction
P3110   IGCT relay is always closed
P3115   33 HV battery current sensor malfunction
P3115   System Main Relay Malfunction
P3120   HV Transaxle Malfunction
P3125   34 Converter & Inverter Assembly Malfunction
P3130   Inverter Cooling System Malfunction
P3135   Circuit Breaker Sensor Malfunction
P3140   Interlock Malfunction
P3145   Vehicle Speed Sensor Circuit Malfunction
Оффлайн swamp lord
  • Карма: +79/-0
  • Андрей я
Re: Коды ошибок оригинального протокола "Toyota"
« Ответ #1 : 10 Февраля 2011, 17:07 »
если уже было или не сильно надо , то убейте тему :)
« Ответ #2 : 11 Февраля 2011, 02:02 »
Подождём, может кто заинтересуется.
Оффлайн DangerWind
  • msk
  • Карма: +91/-0
  • ROCK-N-ROLL жив!
« Ответ #3 : 11 Февраля 2011, 11:21 »
А что можно подключить к машине, чтобы смотреть все показатели? для многих машинок есть бортовые компьютеры и что-то типа ридера (USB и на компьютере можно все посмотретьт), показывают все показатели, ошибки и т.д.
А для нас есть что-то похожее? (больше всего интересует с USB)
Оффлайн Merzavets
  • Горно-Алтайск
  • Карма: +19/-0
« Ответ #4 : 11 Февраля 2011, 20:58 »
Для левого руля много вариантов. Для правого toyota ребята тоже нашли как читать, а вот для правого daihatsu пока тишина. Протокол свой.
Пока только multitroniсs выпускает борт.комп. с поддержкой daihatsu.
Cami turbo aero 2003 22 RUS
Оффлайн AlexeyOrel
  • Orel
  • Карма: +10/-0
  • AlexeyOrel
« Ответ #5 : 17 Февраля 2015, 15:37 »
Привет всем любознательным .. так же возникла заинтересованность  в такой программе  и снятии кодов ошибок ..  Пока так и не понял с какой программой это можно сделать ? :bt:
« Ответ #6 : 17 Февраля 2015, 18:44 »
AlexeyOrel,  тебе в поиск: адаптер k-line и программа TEKU 3. Кажется так. Минимум три темы про диагностику. Для НС только к-лайн.
Оффлайн Cadet
Привет всем, вот прочитал сегодня
Дата: 04.05.2015 Время: 10:40:43
Марка: DAIHATSU
Тип ECU: Powertrain
Автомобиль: DAIHATSU EFI
Текущие ошибки ECU (0)
  Сохраненные ошибки ECU (1)
 001  P1346 Система VVT (датчик, диапазон) Bank1
Куда копать чтобы полечить ??? Машинка Cami 2001
Андрей
« Последнее редактирование: 04 Мая 2015, 11:09 от Gart »
фильтр клапана - клапан - шестерня vvt - цепь грм
посторонние звуки при работе ДВСа? тяга - мощность?? масло какое??
и ещё натяжитель цепи,  вспомнил
« Последнее редактирование: 04 Мая 2015, 11:25 от Царь »
Вам полечить или чтоб работало?
1. масло ...W-30
2. ошибка давнишняя или вчера нарисовалась? Если не "вчера", то сбросить и радоваться до загорания чека.
А если прям горит, как полечить охота, то почистить клапан VVT , и снова на п.2
Оффлайн Cadet
Привет
Спасибо за ответ.
Ошибка висит год. Сегодня сбросил - через 5 километров загорелась снова.
Машина едет хорошо и тяга и мощность в норме. масло 5W40 Toyota из железной канистры.
Почистить клапан ? не было авто с VVT и вообще не знал что есть. как его чистить и где он находится?
Зачем много пробелов между строк?  :nea: Третий раз править не буду, покараю :baklan: Gart. :laugh3:
« Последнее редактирование: 04 Мая 2015, 16:53 от Gart »
1. Масло заменить на 5W30.
...как его чистить и где он нахдится?
Жмакни сверху кнопку "поиск", набери "клапан VVT" и читай :)
Вот, уже сам нашел: http://terios-club.ru/forum/index.php?topic=10109.0
мася не то :crazy:  5w30 должно быть самое жирное
клапан на голове спереди со стороны водителя можно сказать упирается в гидрачь...
кара небесная :crazy: :laugh3: помнишь кину такую :biggrin:
